1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Observations on EPICS Alpha port & DEC support of VxWorks
Date: Thu, 09 Feb 1995 13:58:56 PST
>> Finally, there is the question of channel access, which we have thrashed out
>> before. Final generic support for LE-BE and BE-LE systems will not be
>> implemented until R4 (correct me Jeff if I'm wrong here). In the interim, CA
>> runs on other LE systems (eg VAXes), so I'm not expecting too much trouble
>> here.
>The CA client library will support both ALPHA/OSF and ALPHA/VMS under 3.12
>EPICS. A version 3 EPICS portable CA server is in the works but will not be
>in release 3.12.
>Architecture independent data types ("typedefs") for all of the DBR_XXXX
>types are include in db_access.h for 3.12. To remain portable CA clients
>should use these types for any data requested from or supplied to the CA
>client API.
>Jeff
Thanks Jeff. You are right, they are there in my beta-release version of
R3.12 (Beta1), but they are not yet architecturally defined (they are
unconditionally typedef'ed).
FWIW, Alpha/VMS has short=2, int=4, long=4 and void*=4, unlike Alpha/OSF
(2,4,8,8). VMS has internal constraints (specifically, its implementation of
address space mapping) which make it difficult for it to take full advantage of
the 64bit architecture of the Alpha. This constraint may be relaxed in the
future.
Tony
Dr Anthony D Cox
Computer Systems Specialist
Stanford Synchrotron Radiation Laboratory
Stanford Linear Accelerator Center
MS 69, Box 4349
Stanford CA 94305
[email protected]
Prev: Re: string to binary conversion in the db Tim Mooney
Next: Re: Observations on EPICS Alpha port & DEC support of VxWorks Jeff Hill
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Observations on EPICS Alpha port & DEC support of VxWorks Jeff Hill
