Subject: |
string to binary conversion in the db |
[email protected] (Marty Kraimer) |
Date: |
Fri, 10 Feb 1995 09:13:39 -0600 |
The following changes seem safe (I agree with John that aliasing, etc.
is too dangerous). I also agree that someting should be done because
this request has been expressed previously.
For all the choice types (DBF_ENUM, DBF_GBLCHOICE, DBF_CVTCHOICE,
DBF_RECCHOICE, DBF_RECCHOICE) do the following for DBR_STRING.
1) Compare the string with each string choice just like existing code.
If success then this is just like existing code.
2) If 1) fails then do the following:
perform an sscanf on the string to convert to unsigned int.
If the following are true then change the field:
a) The number of characters consumed = strlen(input string)
b) The index value is < number of choices for the field.
If either a or b is false then fail just like existing code.
Marty Kraimer
Re: string to binary conversion in the db John R. Winans
Re: EPICS on the Alpha 415
<1995>
2025
2026
Observations on EPICS Alpha port & DEC support of VxWorks 415
<1995>
2025
2026
