1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: bug in recCompress.c
Date: Mon, 13 Feb 95 14:39:42 GMT
	I have corrected a bug in the recCompress.c file in EPICS release 3.11.
The AVERAGE algorithm doesn't work when the N field is greater than 1 (!)
because the routine array_average() doesn't update the INX record's field.
The routine must be modified like this:
	/* do we need to calculate the result */
	inx++;
	if (pcompress->n<=0) pcompress->n=1;
	n = pcompress->n;
	pcompress->inx = inx;    <---- add this line
	if (inx<n) return(1);
	if (n>1) {
		pcompress->inx = 0;    <---- and this line
		psum = (double *)pcompress->sptr;
		multiplier = 1.0/((double)n);
		for (i = 0; i < nuse; i++, psum++)
	    		*psum = *psum * multiplier;
	put_value(pcompress,pcompress->sptr,nuse);
	return(0);
A suggestion for the compress record type:
in 3.11 it's not possible to modify the N field of a compress record from
an application. For that, the N field definition in the compressRecord.ascii
file need to be changed like this:
(before)    "N to 1 Compression"     N    SPC_NOMOD  DBF_ULONG   ...
(after)     "N to 1 Compression"     N    SPC_RESET  DBF_ULONG   ...
	Yves Lussignol.
Prev: Re: Making releases Noboru Yamamoto
Next: Re: bug in recCompress.c Rozelle Wright
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Making releases Alan K Biocca
