1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: bug in recCompress.c
Date: Mon, 13 Feb 95 08:14:05 MST
Yves Lussignol writes
> 	I have corrected a bug in the recCompress.c file in EPICS release 3.11.
> The AVERAGE algorithm doesn't work when the N field is greater than 1 (!)
> because the routine array_average() doesn't update the INX record's field.
At Los Alamos, we have used averaging with compression records for a long time
and I was surprised by your note, then I realized that we were using only the
compress_scalar averaging, which is OK.  We also made a version of the
compression record that allows the value of N to be changed. I think
this is a needed improvement.
I hope your corrections get put into the next releases of EPICS.
Rozelle Wright
|Rozelle Wright              Phone (505) 667-4804       |
|Los Alamos Natl Labs AOT-8  FAX (505) 665-5107         |
|PO Box 1663 MS-H820         Group Office (505) 667-6087|
|Los Alamos, NM 87545        email : [email protected]   |
Prev: bug in recCompress.c F. Gougnaud
Next: Re: EPICS on the Alpha watson
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: bug in recCompress.c Marty Kraimer
