Subject: |
Re: bug in recCompress.c |
[email protected] (Marty Kraimer) |
Date: |
Mon, 13 Feb 1995 12:57:04 -0600 |
> From [email protected] Mon Feb 13 07:38 CST 1995
> Date: Mon, 13 Feb 95 14:39:42 GMT
> From: "F. Gougnaud" <[email protected]>
> To: [email protected]
> Subject: bug in recCompress.c
> Content-Type> : > text>
> Content-Length: 1100
> Hi,
> I have corrected a bug in the recCompress.c file in EPICS release 3.11.
> The AVERAGE algorithm doesn't work when the N field is greater than 1 (!)
> because the routine array_average() doesn't update the INX record's field.
> The routine must be modified like this:
> /* do we need to calculate the result */
> inx++;
> if (pcompress->n<=0) pcompress->n=1;
> n = pcompress->n;
> pcompress->inx = inx; <---- add this line
> if (inx<n) return(1);
> if (n>1) {
> pcompress->inx = 0; <---- and this line
> psum = (double *)pcompress->sptr;
> multiplier = 1.0/((double)n);
> for (i = 0; i < nuse; i++, psum++)
> *psum = *psum * multiplier;
> put_value(pcompress,pcompress->sptr,nuse);
> return(0);
You must have an older version of epics. The current version, which appears
to be equivalent to your suggested changes has the code:
> A static int array_average(pcompress,psource,no_elements)
struct compressRecord *pcompress;
double *psource;
long no_elements;
long i;
long nnow;
long nsam=pcompress->nsam;
double *psum;
double multiplier;
long inx=pcompress->inx;
struct dbAddr *pdbAddr = (struct dbAddr *)(pcompress->inp.value.db_link.pdbAddr);
long ninp=pdbAddr->no_elements;
long nuse,n;
nuse = nsam;
if(nuse>ninp) nuse = ninp;
nnow=nuse;
if(nnow>no_elements) nnow=no_elements;
/* add in the new waveform */
if (inx == 0){
for (i = 0; i < nnow; i++)
*psum++ = *psource++;
for(i=nnow; i<nuse; i++) *psum++ = 0;
}else{
*psum++ += *psource++;
inx++;
if(pcompress->n<=0)pcompress->n=1;
n = pcompress->n;
if (inx<n) {
return(1);
if(n>1) {
pcompress->inx = 0;
return(0);
>suggestion for the compress record type:
> in 3.11 it's not possible to modify the N field of a compress record from
> an application. For that, the N field definition in the compressRecord.ascii
> file need to be changed like this:
> (before) "N to 1 Compression" N SPC_NOMOD DBF_ULONG ...
> (after) "N to 1 Compression" N SPC_RESET DBF_ULONG ...
> Yves Lussignol.
Good suggestion. I am making this change to this field and also to ALG.
Marty
Re: EPICS on the Alpha 415
Re: EPICS on the Alpha watson
<1995>
2025
2026
Re: bug in recCompress.c Rozelle Wright
loading ascii database records Alan K Biocca
<1995>
2025
2026
