1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Postscript Documentation
Date: Wed, 24 May 1995 20:52:04 BST
Stefan,
On Wed, 24 May 95 19:50:19 +0200 Stefan Hippler wrote:
> I cannot print any of the new EPICS postscript documentation.
> Standard message is "Can't select requested paper size for Frame print job!".
> I suggest to remove all PAPER/PAPERSIZE dependencies from the Framemaker
> docs. Or does anybody know a workaround for this problem (e.g. have
> only european A4 paper on my HP Laserjet IV or Apple LaserWriter IIg).
This is a highly annoying feature of FrameMaker Postscript, but I cannot see an
easy way to turn it off.  I have developed the following sed fragment which you
can use to convert the Frame PostScript into something which will print on an A4
PostScript printer such as an HP 4M:
	sed -e 's/ 612 792 / 595.3 841.9 /' sourcefile.ps | lpr
Hope this helps,
- Andrew
  O o ._    Andrew Johnson, Royal Greenwich Observatory
     __\\_	Madingley Road, Cambridge, CB3 0EZ
  __|ooooo|__	Tel +44 (0)1223 374823  Fax 374700
~~\_________/~~	WWW http://www.ast.cam.ac.uk/~anj/
Prev: Problem with MVME167-02B boards Mark Rivers
Next: RE: Problem with MVME167-02B boards Mark Rivers
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Postscript Documentation Stefan Hippler
Next: Re: Postscript Documentation Tim Mooney
