1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: AO rec flaw
To: [email protected]
Date: Tue, 18 Jul 95 15:07:54 MDT
Hello all,
I just observed a passive analog output record that after rec init had
STAT=UDF_ALARM, SEVR=INVALID_ALARM, and UDF=0. My device support
successfully read the initial value out of the device (and
indirectly set UDF to false). Once this record is processed for the
first time then the UDF alarm condition goes away.
This appears to be a flaw in the AO record. The ascii rec def initializes
stat=UDF and sevr=INVALID. When the record inits if we get the value from the
device and the udf field becomes zero then we dont reset stat and sevr.
Most likely we need to call alarm() from within AO rec support just after
calling devRecInit()? Since recGblSetSevr() maximizes the alarm condition
we would need to init stat/sevr to no alarm?
It is hard to believe that this has gone undetected for this long.
Has anyone else noticed a passive AO rec in alarm state UDF that
successfully read its initial value from the IO but hasnt been processed
for the first time?
Jeff
______________________________________________________________________
Jeffrey O. Hill			Internet	[email protected]
LANL MS H820			Voice		505 665 1831
Los Alamos, NM 87545 USA 	FAX		505 665 5107
Prev: Re: Free GDCT and Alpha/Digital Unix Tim Mooney
Next: Re: AO rec flaw Marty Kraimer
Index: 1994  <19951996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
