Using CAPFAST I've tried to connect the .VAL output of an AI record to
an input of my own symbol via same page connectors.
I gave the connectors the same label. I had to rotate the input connector
to get the wire tap on the right side. The wires had appropriate names.
When I try to build it I get a memory fault during the edif->sr conversion.
With just the output same page connector, it builds okay.
With just the input samp page connector, it gives a memory fault.
Is the same page connector not to be used in this manner? If so how should
it be used. Or is there something I'm doing wrong?
Thanks.
Kevin Tsubota
[email protected]
W.M Keck Observatory
P.O. Box 220
Kamuela, HI 96743
Internal type conversion in EPICS Andy Foster
Re: capfast onpage / same page connector Matthew Needes (LANL)
<1995>
2025
2026
Re: AO rec flaw Jeff Hill
<1995>
2025
2026
