Marty Kraimer writes:
> Can you isolate the example to just 2 soft records and then send
> me the .db format database.
Hmm. The original example had A as a LONGOUT record and B as a CAD
record (from Gemini). I just tried it with B as both a LONGOUT and a
LONGIN and it works!
So this seems to be record type dependent.
Case I: (doesn't work)
record(longout,"cp:if:mcs:dir") {
field(DESC,"long output record")
field(SCAN,"Passive")
field(PINI,"NO")
field(PHAS,"0")
field(EVNT,"0")
field(DTYP,"Soft Channel")
field(DISV,"1")
field(SDIS,"0.000000000000000e+00")
field(DISS,"NO_ALARM")
field(PRIO,"LOW")
field(FLNK,"0.000000000000000e+00")
field(OUT,"mcs:cmd:move.DIR .PP .NMS")
field(DOL,"0.000000000000000e+00")
field(OMSL,"supervisory")
field(EGU,"units")
field(HOPR,"0")
field(LOPR,"0")
field(HIHI,"0")
field(LOLO,"0")
field(HIGH,"0")
field(LOW,"0")
field(HHSV,"NO_ALARM")
field(LLSV,"NO_ALARM")
field(HSV,"NO_ALARM")
field(LSV,"NO_ALARM")
field(HYST,"0")
field(ADEL,"0")
field(MDEL,"0")
field(SIOL,"0.000000000000000e+00")
field(SIML,"0.000000000000000e+00")
field(SIMS,"NO_ALARM")
field(IVOA,"Continue normally")
field(IVOV,"0")
record(car,"mcs:cmd:move_car") {
field(DESC,"CAR record")
field(PINI,"NO")
field(PHAS,"0")
field(EVNT,"0")
field(DISV,"1")
field(ERSV,"NO_ALARM")
field(PRIO,"LOW")
Case II: (works)
record(longin,"test:b") {
field(DESC,"long input record")
field(PINI,"NO")
field(PHAS,"0")
field(EVNT,"0")
field(DISV,"1")
field(PRIO,"LOW")
field(INP,"0.000000000000000e+00")
field(EGU,"volts")
field(HOPR,"0")
field(LOPR,"0")
field(HIHI,"0")
field(LOLO,"0")
field(HIGH,"0")
field(LOW,"0")
field(HYST,"0")
field(ADEL,"0")
field(MDEL,"0")
record(longout,"test:a") {
field(PINI,"NO")
field(PHAS,"0")
field(EVNT,"0")
field(DISV,"1")
field(PRIO,"LOW")
field(OUT,"test:b.VAL .PP .NMS")
field(EGU,"units")
field(HOPR,"0")
field(LOPR,"0")
field(HIHI,"0")
field(LOLO,"0")
field(HIGH,"0")
field(LOW,"0")
field(HYST,"0")
field(ADEL,"0")
field(MDEL,"0")
field(IVOV,"0")
Peregrine
- Re: Vanishing OUTLINKS Marty Kraimer
- Vanishing OUTLINKS Peregrine McGehee
<1996>
2025
2026
<1996>
2025
2026
