Peregrine McGehee wrote:
> Marty Kraimer writes:
> > Can you isolate the example to just 2 soft records and then send
> > me the .db format database.
> Hmm. The original example had A as a LONGOUT record and B as a CAD
> record (from Gemini). I just tried it with B as both a LONGOUT and a
> LONGIN and it works!
I will make a wild guess about what is happening.
After the first time the CAD record is processed
it puts itself into a state such that it is not
processed by the longout record.
Does it change it's scan mechanism?
If it is active or disabled you should see
a message when TPRO is on.
Try nthe following:
reboot
Do a dbpr
"<cad record>",4
before first dbpf
after dbpf
after 2nd dbpf
Does anything make sense?
Marty Kraimer
- Re: Vanishing OUTLINKS Peregrine McGehee
- Vanishing OUTLINKS Peregrine McGehee
- Re: Vanishing OUTLINKS Marty Kraimer
<1996>
2025
2026
<1996>
2025
2026
