>Are there any special configuration changes to EPICS or the vxWorks kernel
>when using the hknitro60? We're getting access violations that appear
>to be related to interrupts when we start monitoring. This might be
>a 68060-related issue. I know that vxworks doesn't use separate interrupt
>stacks when a 68060 is used.
>I just want to make sure that I'm not tracking something that has already
>been addressed before.
What is 'monitoring'??
What addresses are you getting errors on?
Should these be otherwise valid addresses?
The stack stuff should be OK, I'd do a "checkStack" and "memShow 1" to
see if vxWorks is sane before and after these obscure IRQs.
I have run a software-only EPICS database on the nitro-60 using NO
other VME hardware in the crate and it appeared to run OK. The only
reason for alterations to the vxWorks kernel would be determined
entirely by the other hardware you wish to use in the crate.
I am not entirely sure, but I believe that the A16 area to be safe
as-shipped. Your A24 and A32 regions probably require some hackery in
the sysLib.c file.
--John Winans
- Hknitro60 + epics Greg Greene
Re: COMMUNICATION between EPICS and the Allen Bradley SLC 500 Marty Kraimer
Re: SNL exit question Jeff Hill
<1996>
2025
2026
RE: COMMUNICATION between EPICS and the Allen Bradley SLC 500 415
<1996>
2025
2026
