1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: SNL exit question
To: Len Lawrence <[email protected]>
Cc: tech-talk EPICS <[email protected]>
Date: Fri, 30 Aug 1996 12:56:54 -0600
Len Lawrence wrote:
> Sorry folks - wrong end of the stick again.  The exit command does not give
> the user the ability to terminate the process but only to perform actions
> on closedown.  The normal C exit function compiles all right but is it the
> correct way to kill a process in EPICS?
Calling exit() within the vxWorks environment causes the vxWorks
task to terminate. This will cause CA to clean up via its task
delete handler. The sequencer also has a task exit handler and it
should also cleanup when an abrupt task termination occurs.
Calling "exit()" from with in the sequence program should be
roughly equivalent to deleting a sequence program task from the shell.
Jeff
______________________________________________________________________
Jeffrey O. Hill			Internet	[email protected]
LANL MS H820			Voice		505 665 1831
Los Alamos, NM 87545 USA 	FAX		505 665 5107
Re: SNL exit question Len Lawrence
Prev: Re: Hknitro60 + epics John R. Winans
Next: iocLog - wishlist Gabor Csuka
Index: 1994  1995  <19961997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: SNL exit question Len Lawrence
Next: Hknitro60 + epics Greg Greene
