1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Changing MBBO state strings & CA Clients
To: [email protected], [email protected]
Date: Fri, 7 Mar 97 08:10:01 MST
The caching of the strings for enums is the responsibility of the client.
Most clients fetch the type DBR_CONTROL_xxx at connection and then
only monitor the value/timestamp/status. This is true of CAU, DM, MEDM
at least. For a client to get the changes in the middle of operation
they would either have to
1)monitor the entire structure and then the network traffic is increased
	significantly
2) do gets - then you have a polled system with increased struture size
We are now considering as one of the extensions to channel access in
version 4 - adding an event type that lets a regular monitor know that
the parameters that make up the largest composite type have changed -
then the client can reacquire the larger structure. Needless to say,
this is not yet done.
One way to prove that the string is working is to use the
dbpf - utility in the IOC.
Do you do this in an operational system - or as you are developing
an application?
	Bob
Prev: Changing MBBO state strings & CA Clients Andrew Johnson
Next: Re: Changing MBBO state strings & CA Clients Jeff Hill
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Changing MBBO state strings & CA Clients Jeff Hill
Next: Collaboration Meeting in May Bob Dalesio
