1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Changing MBBO state strings & CA Clients
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 07 Mar 1997 10:41:08 -0700
Andrew Johnson wrote:
> Is this expected behaviour (3.12.2), and is the cacheing implemented in
> the CA client library or in the server?
There is no caching of this sort in the client/server libraries.
I suspect that the caching is occuring inside of dm and or cau.
Changes allowing enum state string monitoring (and other user
defined event types) are anticipated for EPICS V4.
Jeff
______________________________________________________________________
Jeffrey O. Hill                 Internet        [email protected]
LANL MS H820                    Voice           505 665 1831
Los Alamos, NM 87545 USA        FAX             505 665 5107
Changing MBBO state strings & CA Clients Andrew Johnson
Prev: Re: Changing MBBO state strings & CA Clients Bob Dalesio
Next: Re: MVME177 and vxWorks John R. Winans
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Changing MBBO state strings & CA Clients Andrew Johnson
Next: Re: Changing MBBO state strings & CA Clients Bob Dalesio
