1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Changing MBBO state strings & CA Clients
To: EPICS tech-talk <[email protected]>
Date: Fri, 07 Mar 1997 09:50:59 +0000
I've recently noticed that if I change the state strings in an MBBO
record I can apparently only use the new strings as a valid states by
opening a new CA client connection to the IOC -- I have to run cau/dm
again before the valid strings change.  I can understand that a dm
choice button would only get the state strings once when the chennel
connects, but I was only doing get/put requests through cau (no
monitors) so I was surprised by the state string cacheing.  Attempts to
set the record value using the new strings are rejected and the old
strings listed as legal values, and this persists for long-running
clients even when more recent clients can use the new strings.
Is this expected behaviour (3.12.2), and is the cacheing implemented in
the CA client library or in the server?
-- Andrew
   ___
 .'   `.	Andrew Johnson, Head of Electronics
/ Royal )	Royal Greenwich Observatory
\ Greenwich	Madingley Road, Cambridge, CB3 0EZ
| Observatory	Tel: +44 1223 374823   Fax: 374700
+----------	WWW: http://www.ast.cam.ac.uk/~anj
Re: Changing MBBO state strings & CA Clients Jeff Hill
Prev: Re: VxWorks file i/o problem Chip Watson
Next: Re: Changing MBBO state strings & CA Clients Bob Dalesio
Index: 1994  1995  1996  <19971998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: v 3.13 release Bill Brown
Next: Re: Changing MBBO state strings & CA Clients Jeff Hill
