1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: first serial devSupp.
To: "Peregrine M. McGehee" <[email protected]>
Cc: Allan Honey <[email protected]>, [email protected], [email protected]
Date: Mon, 23 Feb 1998 09:24:40 -1000
Peregrine M. McGehee wrote:
> Aloha,
> > > I must  write a small RS232 devSupport.
> > > Is there a sample skeleton template to costruct it ?
> > > or Are there any example to make it ?
> > > I haven't found nothing in the my documentation, is there
> > > a doc. in www ( as Gpib) ?
> > > I'm using R.3.13.0beta11, MVME162, Sun Ultra, VxWorks 5.2.
> > What is the nature of your RS232 device? If it is a device which responds
> > to prompts, that is it does not send data asynchronously, then we may
> have
> > a driver that will work. The driver is drvAscii which is layered on top
> > of drvSerial - written for Keck observatory by Jeff Hill of LANL. The
> driver
> > is in use in several other telescopes and accelerators. The driver
> simplifies
> > our life a lot.
> And... drvSerial assumes that you have a standard vxWorks ty driver for
> your serial I/O hardware - and that you create named devices within VxWorks
> (for example: /dev/co, /dev/fs2, etc).
We're using drvAscii/drvSerial with Bret Goodrich's tnetdev, running
our serial line devices on a terminal server, over Ethernet. This
works even to the point that some time ago we had the serial line
devices at the telescope with the VME crate in Hilo.
Maren Purves
Re: first serial devSupp. Peregrine M. McGehee
Prev: Re: first serial devSupp. Allan Honey
Next: GPIB+VxWorks3.5.1 problem Josep A. Perlas
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: first serial devSupp. Peregrine M. McGehee
Next: Re: first serial devSupp. Tim Mooney
