1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Monitors on a stringin record
To: [email protected], [email protected]
Date: Thu, 10 Dec 1998 18:37:21 -0600
re...
> Am I correct in assuming that value change monitors
> are invoked on a stringin record *only* if OVAL is
> not equal to VAL?  Is there any way that a stringin
> record can be set to trigger monitors "ALWAYS"?
If you really do need exactly this behavior, and you don't want
to write custom record or device support, you could make the stringin
record's OVAL field writable (copy $BASE/src/rec/stringinRecord.dbd
to your src directory, delete "special(SPC_NOMOD)" from the OVAL
field's attribute list, and rebuild) and arrange for a stringout
record to write to it (through an NPP link) after the stringin record
processes.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab
Prev: Re: Links between IOCs Tim Mooney
Next: RE: Links between IOCs Mark Rivers
Index: 1994  1995  1996  1997  <19981999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Monitors on a stringin record Ralph Lange
Next: Re: Monitors on a stringin record Mark Rivers
