1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VxWorks global variable device support
To: [email protected]
Cc: [email protected]
Date: Tue, 1 Feb 2000 08:40:21 -1000
Ralph,
Thanks for the analysis:
>For an output, I can think of three reasonable choices that may be
>controlled without having to introduce another field in OUT:
>1. PINI = NO, DOL = don't care...
>2. PINI = YES, DOL is set (constant or link)...
>3. PINI = YES, DOL is not set...
Given the following...
>Some of the database configuration tools (i.e. CapFast) do not handle
>the new situation correctly. Users may have problems as they might not
>be able to _not_ set a DOL field...
...I feel that there _should_ be explicit control over whether output records
read the VxWorks variable at initialization time. Also, I think that
this is necessary in order to achieve backwards compatibility.
Also, Bob D suggested allowing the direct specification of an address. I
have permitted this (if the global variable doesn't exist, the name is
passed to strtoul(), so octal, decimal and hexadecimal are all
allowed).  The result is that you can now use VxWorks global variable
device support for direct access to device registers if you so desire.
William
Re: VxWorks global variable device support Ralph . Lange
Prev: cd2400 or z85230 serial driver ioctl options Porter, Rodney
Next: gdct313 Linux executable ? Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VxWorks global variable device support Ralph . Lange
Next: Re: VxWorks global variable device support Ralph . Lange
