1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VxWorks global variable device support
To: [email protected] (William Lupton)
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 2 Feb 2000 11:32:09 +0100 (MET)
  > ...I feel that there _should_ be explicit control over whether
  > output records read the VxWorks variable at initialization
  > time. Also, I think that this is necessary in order to achieve
  > backwards compatibility.
I don't think anyone ever set an output record to PINI=YES without
setting DOL, right? So ... if one uses a tool from the olden days (that
always puts something into DOL), everything will still work the same.
The only way to mess up things is using an editor or a new db generation
tool, not setting the DOL field and continue believing that this means a
CONSTANT 0. (Which isn't true anymore, anyway.) This would make the
record read the variable unintentionally.
Do you actually think someone might run into this?
  > The result is that you can now use VxWorks global variable device
  > support for direct access to device registers if you so desire.
Which (if the addresses are mapped to VME address space) - *sigh* - pops
up the topic of semaphore guarding again ... can you promise that all
kinds of VME accesses on all architectures using all the possible VME IO
cards are non-interruptable?
You should at least include a warning message in the doc (24pt bold red).
Ralph
Re: VxWorks global variable device support William Lupton
Prev: gdct313 Linux executable ? Brian McAllister
Next: Re: VxWorks global variable device support William Lupton
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VxWorks global variable device support William Lupton
