1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VxWorks global variable device support
To: [email protected], [email protected]
Cc: [email protected]
Date: Thu, 3 Feb 2000 10:11:18 -0700
> I don't know enough about how Bob's archiver handles these bumpless
> reboot situations. (I guess it is by IOC, not by record.) Most of our
> outputs are read back during IOC initialisation (the inherent luxury of
> a fieldbus based design) --- this is handled record-wise by device
> support looking at the PINI field.
> Specifying "readback wanted" in the OUT link seems absolutely
> appropriate in your case.
> Maybe all output records should have a menu-type field that specifies if
> readback at init time should be performed.
> Should they?
> Ralph
I don't like to have to process the output records and cause any resulting
processing just to get the current value of an output record after a reboot,
so it would be great to add the selectable readback to all output records
or add something like RINI (read at initialization) to read but not process.
We might consider one additional subtlety for those of us who use STAT and/or
SEVR, particularly to display value with a color rule that indicates these
values.  If an output record had readback but was not processed, would it affect
STAT and/or SEVR values.  Right now I think these are usually UDF and INVALID
respectively until the record is processed.
Re: VxWorks global variable device support Ralph . Lange
Re: VxWorks global variable device support Nick Rees
Prev: RE: Python/CA Jeff Hill
Next: Re: VxWorks global variable device support (capfast can default DOL to not set) Rozelle Wright
Index: 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VxWorks global variable device support Ralph . Lange
Next: Re: VxWorks global variable device support Ralph . Lange
