1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VxWorks global variable device support
To: [email protected]
Date: Thu, 3 Feb 2000 08:26:02 -1000 (HST)
On Thu, 3 Feb 2000, Deb Kerstiens wrote:
> I don't like to have to process the output records and cause any resulting
> processing just to get the current value of an output record after a reboot,
> so it would be great to add the selectable readback to all output records
> or add something like RINI (read at initialization) to read but not process.
While we are on the subject (which has diverged somewhat from the original
one), I have often had the similar problem caused by rebooting fieldbus
modules but not the IOC. In this case I have occasionally wanted my output
record to readback the new value (post-reboot) from the fieldbus module,
rather than set it to the last EPICS value. Hence I have always felt there
was a better way of handling this re-initialization of output records.
I have also found the treatment of all these things a bit inconsistent -
especially as the code resides in device, rather than record, support (and
so is developed by a greater number of programmers). One thought I had was
to support a read routine in device support of output records, and then
move a bit of the logic back into the record. We could also support a
callback when the output hardware re-inialises. I admit that this is
difficult to make backwards compatible.
Just a few thoughts to create a few more ideas. I must admit I only
scanned Andrew's new link notes, so I can't remember how much of this is
addressed by his ideas.
Cheers
Nick Rees
Joint Astronomy Centre               Ph:       +1 (808) 961-3756
660 N. Aohoku Place                  Fax:      +1 (808) 961-6516
Hilo, HI.  96720                     Internet: [email protected]
RE: VxWorks global variable device support Jeff Hill
Re: VxWorks global variable device support Deb Kerstiens
Prev: Re: VxWorks global variable device support Deb Kerstiens
Next: Re: VxWorks global variable device support William Lupton
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VxWorks global variable device support Ralph . Lange
Next: RE: VxWorks global variable device support Jeff Hill
