1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VxWorks global variable device support
To: [email protected], [email protected]
Cc: [email protected]
Date: Thu, 3 Feb 2000 08:51:04 -1000
Dear all,
Fragments from Ralph and Deb's postings...
>>> We might consider one additional subtlety
>> Just one?
>>> for those of us who use STAT and/or
>>> SEVR, particularly to display value with a color rule that indicates these
>>> values.  If an output record had readback but was not processed, would it
>>> affect STAT and/or SEVR values.  Right now I think these are usually UDF
>>> and INVALID respectively until the record is processed.
>> Good point. As the record is defined after reading back the value,
>> UDF/INVALID is inappropriate. Would you think we need to have another
>> status that announces that the value has been read back and is valid, but
>> the record hasn't been processed yet? Or would that be too subtle a
>> difference to be signalled?
The existing output record device support that I have looked at (_not_
an exhaustive test) looks something like this (from devBoXVme220.c)...
        status = xy220_read(pvmeio->card,pbo->mask,&value);
        if(status == 0) pbo->rbv = pbo->rval = value;
        else status = 2;
	return(status);
...so if the readback succeeds, RVAL is set to the readback value and a
zero status is returned, which (for bo anyway) will do...
        if(status==0) {
                if(pbo->rval==0) pbo->val = 0;
                else pbo->val = 1;
                pbo->udf = FALSE;
        } else if (status==2) status=0;
...so RVAL will be converted to VAL and UDF will be cleared. If the readback
failed, then a status of 2 is returned, no conversion to VAL occurs, and UDF
is left unchanged.
So I think that the UDF/INVALID side of things is already handled.
William
Prev: Re: VxWorks global variable device support Nick Rees
Next: RE: VxWorks global variable device support Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  <2000>  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: VxWorks global variable device support Deb Kerstiens
Next: Re: VxWorks global variable device support Tim Mooney
