1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Fatal GDD deficiencies
To: <[email protected]>
Cc: "EPICS-tech-talk" <[email protected]>
Date: Wed, 8 Mar 2000 10:24:20 -0700
Ralph,
My first comment is that I am fixing all bugs and deficiencies
in the GDD code as they are discovered. This unfortunately has been a
significant effort. In the long term we have prepared a vastly simpler and
more efficient alternative to GDD which we intend to support in parallel to
GDD via a new base class for class "casPV".
>  1) For easy-to-use and fast gdd assignments, the operator = is
>     overloaded in gddI.h to use memcpy().
>     (I thought memcpy() was the default for operator =, but anyway.)
>     When this operator is used to assign gdds that are container
>     members, the pointer to the next element is included in the memcpy()
>     and screws up the member lists of both containers.
This bug appears to still be in the version in CVS. Will you be committing
a fix to the main trunk?
>     The frequently used gddApplicationTypeTable function to create
>     standard gdds returns a gdd*. So using operator [] will do regular
>     pointer arithmetics and not use the overloaded operator.
>     Even if you use a gddContainer* (through a dangerous cast) the
>     overloaded operator [] takes an unsigned int as index argument
>     whereas the constants defined in gddApps.h are signed.
The version committed to CVS appears to have overloaded [] operator in class gdd
for both integer and unsigned indexes. These operators should also be in class
gddContainer since it publicly derives from gdd. I created this patch last spring
but it appears to have been committed to CVS in August of last year. NOTE THAT
IN C++ THE OVERLOADED [] OPERATOR WILL BE USED ONLY IF YOU ARE DIRECTLY ACCESSING
THE OBJECT OR USING A REFERENCE TO THE OBJECT. THE BUILT-IN [] OPERATOR IS ALWAYS
USED BY C++ WHEN A POINTER IS ACCESSING THE OBJECT.
>     New standard gddContainer objects (created using the AppTypeTable)
>     are always malloc'd as one contiguous block, so pointer arithmetics
>     will work. By chance.
In Jim's nomenclature a container GDD can be "flat". If it is flat the
container is just a linear array of GDDs that can be indexed with the default
C++ [] operator. Last spring I found a nasty bug where internally GDD's "dbMapper.cpp"
was using the [] operator, but not checking to see if the container was flat. My fix
was to overloaded the [] operator so that the behavior is different when the GDD
container is scattered around in memory and accessed as a linked list, and therefore not
"flat". The performance will of course be abysmal, but at least we can get reliable
operation in all situations. This fix is committed to CVS.
> (... live from the coding dungeon)
Join the club. I have been stuck with the GDD dungeon since Jim left.
Jeff
Fatal GDD deficiencies Ralph . Lange
Prev: Channel Access for Macintosh? Steve Lewis
Next: GPIB Devices Robert Willson
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Fatal GDD deficiencies Ralph . Lange
Next: Channel Access for Macintosh? Steve Lewis
