1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: C++ API backwards compatibility
Cc: [email protected]
Date: Fri, 08 Dec 2000 09:09:09 -0500
Andrew,
  I now understand better what you intend.  But the sort of
"undefined" behaviors I've encountered are fairly arcane problems
arising from vaguaries in the standard.  For example, consider the
following:
  list<t> my_list;
  list<t>::const_itertor it;       // read-only iterator
  it = my_list.begin();
  if (it != my_list.end()) cout << "groovy" << endl;
The comparison between an iterator and a const_iterator is not
defined by the standard.  The only portable solution is to
cast my_list.end() to a const iterator:
  if (it != (list<t>::const_iterator)my_list.end())
But, both g++ and MS VC++ quietly permit the first comparison,
while the HP aCC compiler specifically disallows it, specifically
because it's undefined.  You might take this in one of two ways:
either as evidence that HP is behind the times, or that HP avoids
supporting de facto standards.
If you're interested, here's some email I sent to the HP aCC mailing
list:
Howdy,
  After reviewing the comments posted on this list, and looking
over the ISO/IEC 14882 standard, I've come to the conclusion
that the best thing to do is to cast the iterator returned by
end() to a const_iterator.  Here's why:
  list<t>::end()           --> returns an iterator
  const list<t>::end()     --> returns a const_iterator
but,
  list<t>::iterator        --> references a t
  list<t>::const_iterator  --> references a const t
  Now, the standard explicitly states that an iterator can
be explicitly converted to a const_iterator, so the following
is perfectly valid:
  class blah
    list<t>  my_list;
    void f1 (void)
  Given that the standard allows a conversion from iterator -->
const_iterator, you might think that the overloaded != operator
should perform the conversion implicitly.  The rules governing
how the operands to such a method are selected allow a less-qualified
type to be implicitly converted to a more qualified type.  Here,
however, the relationship between (class iterator --> class
const_iterator)
is not the same as the relationship between (class a --> const class a).
  So the problem is sort of this disconnect between what is happening
intuitively and what is happening technically.  Apparently testing
equality between iterator and const_iterator objects is a desired
feature for the next revision of the standard.  See:
  http://anubis.dkuug.dk/jtc1/sc22/wg21/docs/lwg-active.html#179
  Best Regards,
Chris
Christopher A. Larrieu
Computer Scientist, Acc. Controls Group
Thomas Jefferson National Accelerator Facility
Re: C++ API backwards compatibility Andrew Johnson
C++ API backwards compatibility Jeff Hill
Re: C++ API backwards compatibility Chris Larrieu
Prev: Re: C++ API backwards compatibility Andrew Johnson
Next: Re: C++ API backwards compatibility Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  <20002001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
