1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: GPIB: To FLNK or Not to FLNK
To: [email protected]
Date: Mon, 12 Feb 2001 17:02:50 -1000
Hello.
I seem to have a two-fold problem:
Fold 1:
I'm using a sequence record to process 10 (sequential) calls to GPIB hardware.
Just 10 Analog Input records.
Because the call to hardware LNK1 takes time (t >0) to complete, LNK2 will
start *before* LNK1 is complete. Since this is unacceptable in my design,
I have to induce a delay between LNK's in the sequence record. For example, I
have a 3 second delay between each call to an analog Input. The sequence record
will finish all 10 LNK's in 30 seconds.
You might ask, "Why is he using a sequence record when he could just FLNK the
harware calls in a serial fashion and do away with the sequence record, and
ultimately the need for a delay?".
Fold 2:
I want the functionality to turn on or off LNK's. I believe this could
be implemented with the SELM = MASK field in the sequence record.
Any hints on how to implement this?
Much obliged.
-Mathew Rippa
	~Joint Astronomy Centre
Prev: Re: edd manual Steve Lewis
Next: Re: GPIB: To FLNK or Not to FLNK Ned Arnold
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
