> Hello all,
> I'm wanting to use the state code escaped C versions of the pvPut/Get(),
> etc, ie. seq_pvPut/Get(). From the SNL User Guide I've found the first
> parameter to these functions is the state set identifier (SS_ID) of the
> calling state set, please can someone tell me how I may obtain this?
> I'm using vxWorks 5.3, EPICS 3.13.2 and SNC/SEQ Version 1.9.2.Beta12.
> Many thanks,
> Alastair B.
Alastair,
It gets defined for you in the .c file that is generated by the SNC compiler.
Escaped c code will find it. Here is a typical example ...
At the beginning of the file ...
%%#include <seq.h>
%%static long putAndWait(SS_ID ssId, int pvId, chtype type, void *value);
int sendStringId;
With the sequence code ...
state init
when ()
sendStringId = pvIndex(sendString);
} state wait_for_command
when (1)
%% putAndWait(ssId, sendStringId, DBR_STRING, sendString);
In the escaped C-code ...
SEM_ID waitingSem = NULL;
static void myCallback();
unsigned long count = 1;
long result;
chid chanId;
SPROG *pSP; /* ptr to state program */
CHAN *pDB; /* ptr to channel struct */
/* See if the semaphore has been initialized yet */
if(!waitingSem) {
waitingSem = semBCreate(SEM_Q_FIFO,SEM_EMPTY);
/* find chid from sequencer's structures */
pSP = ((SSCB *)ssId)->sprog;
pDB = pSP->pChan + pvId;
chanId = pDB->chid;
result = semTake(waitingSem, NO_WAIT); /* clear semaphore */
ca_array_put_callback(type, count, chanId, value, myCallback, NULL);
ca_flush_io();
result = semTake(waitingSem, 600);
return(result);
void myCallback()
semGive(waitingSem);
Ned
ss_id for seq_pv functions Alastair Borrowman
Re: dm2k on alpha Brian McAllister
<2001>
2025
2026
Support for Allen-Bradley PLCs Rarback, Harvey
<2001>
2025
2026
