Marty Kraimer wrote:
> I have had some private message with Andy Foster about this problem. We are making
> changes to devVXStats to fix the problem. As soon as we have done some more
> testing I will make the new code available. Andy also reports that the new
> algorithm for computing cpu usage is more stable.
I am attaching the latest version that has been tested on both 68K and powerPC.
Marty Kraimer /* devVXStats.c - Device Support Routines for vxWorks statistics */
* Original Author: Jim Kowalkowski
* Date: 2/1/96
* Current Author: Marty Kraimer
* Date: 18NOV1997
COPYRIGHT NOTIFICATION
(C) COPYRIGHT 1993 UNIVERSITY OF CHICAGO
This software was developed under a United States Government license
described on the COPYRIGHT_UniversityOfChicago file included as part
of this distribution.
#include <vxWorks.h>
#include <stddef.h>
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <math.h>
#include <taskLib.h>
#include <wdLib.h>
#include <tickLib.h>
#include <sysLib.h>
#include <alarm.h>
#include <dbDefs.h>
#include <dbScan.h>
#include <dbAccess.h>
#include <callback.h>
#include <recSup.h>
#include <devSup.h>
#include <link.h>
#include <aiRecord.h>
#include <aoRecord.h>
The following device definitions must exist
device(ai,INST_IO,devAiVXStats,"VX stats")
device(ao,INST_IO,devAoVXStats,"VX stats")
sample db file to use all data available:
Notive that the valid values for the parm field of the link
information are:
ai:
memory - % memory used
cpu - % CPU usage by tasks
fd - % of file descripters used
ao:
memoryScanPeriod - Set memory scan period
cpuScanPeriod - Set cpu scan period
fdScanPeriod - Set fd scan period
# sample database using all the different types of statistics
record(ai,"$(IOC):memory")
field(DTYP,"VX stats")
field(SCAN,"I/O Intr")
field(INP,"@memory")
field(HOPR,"100.0")
field(HIHI,"90.0")
field(HIGH,"60.0")
field(HHSV, "MAJOR")
field(HSV, "MINOR")
record(ai,"$(IOC):cpu")
field(INP,"@cpu")
field(HOPR,"100.0")
field(HIHI,"90.0")
field(HIGH,"60.0")
field(HSV, "MINOR")
record(ai,"$(IOC):fd")
field(INP,"@fd")
field(HOPR,"100.0")
field(HIHI,"90.0")
field(HIGH,"60.0")
field(HSV, "MINOR")
record(ao,"$(IOC):memoryScanPeriod")
field(OUT,"@memoryScanPeriod")
record(ao,"$(IOC):fdScanPeriod")
field(OUT,"@fdScanPeriod")
record(ao,"$(IOC):cpuScanPeriod")
field(OUT,"@cpuScanPeriod")
typedef struct aiaodset
long number;
DEVSUPFUN report;
DEVSUPFUN init;
DEVSUPFUN init_record;
DEVSUPFUN get_ioint_info;
DEVSUPFUN read_write;
DEVSUPFUN special_linconv;
}aiaodset;
typedef struct devPvt
int type;
}devPvt;
static long ai_init(int pass);
static long ai_ioint_info(int cmd,aiRecord* pr,IOSCANPVT* iopvt);
static long ai_init_record(aiRecord*);
static long ao_init_record(aoRecord* pr);
static long ai_read(aiRecord*);
static long ao_write(aoRecord*);
aiaodset devAiVXStats={ 6,NULL,ai_init,ai_init_record,ai_ioint_info,ai_read,NULL };
aiaodset devAoVXStats={ 6,NULL,NULL,ao_init_record,NULL,ao_write,NULL };
#define MEMORY_TYPE 0
#define CPU_TYPE 1
#define FD_TYPE 2
#define TOTAL_TYPES 3
/* default rate in seconds (memory,cpu,fd) */
static int default_scan_rate[] = { 10,50,10 };
static char *aiparmValue[TOTAL_TYPES] = {"memory","cpu","fd"};
static char *aoparmValue[TOTAL_TYPES] = {
"memoryScanPeriod","cpuScanPeriod","fdScanPeriod"};
typedef struct scanInfo
IOSCANPVT ioscanpvt;
WDOG_ID wd;
int rate_tick; /* ticks */
}scanInfo;
static scanInfo scan[TOTAL_TYPES];
static void wdCallback(int type);
static double getMemory(void);
static double getFd(void);
#define SECONDS_TO_STARVATION 60
#define SECONDS_TO_BURN 5
#define SECONDS_TO_WAIT 15
typedef struct cpuUsage {
SEM_ID lock;
unsigned long ticksToDeclareStarvation;
unsigned long ticksToBurn;
unsigned long ticksToWait;
double nBurnNoContention;
unsigned long ticksLastUpdate;
double usage;
} cpuUsage;
static cpuUsage usage;
static void wdCpu(void);
static double cpuBurn();
static void cpuUsageTask();
static double getCpu(void);
static void cpuUsageInit(void);
int type;
if(pass==1) {
for(type=0;type<TOTAL_TYPES;type++) {
if(type==CPU_TYPE) {
wdStart(scan[type].wd,scan[type].rate_tick,
(FUNCPTR)wdCpu,0);
} else {
(FUNCPTR)wdCallback,type);
return(0);
scanIoInit(&scan[type].ioscanpvt);
scan[type].wd=wdCreate();
scan[type].rate_tick=default_scan_rate[type]*sysClkRateGet();
cpuUsageInit();
return 0;
devPvt* pvt=(devPvt*)pr->dpvt;
*iopvt=scan[pvt->type].ioscanpvt;
return 0;
static long ai_init_record(aiRecord* pr)
int type;
devPvt* pvt = NULL;
char *parm;
if(pr->inp.type!=INST_IO) {
recGblRecordError(S_db_badField,(void*)pr,
"devAiStats (init_record) Illegal INP field");
return S_db_badField;
parm = pr->inp.value.instio.string;
for(type=0; type < TOTAL_TYPES; type++) {
if(strcmp(parm,aiparmValue[type])==0) {
pvt=(devPvt*)malloc(sizeof(devPvt));
pvt->type=type;
if(pvt==NULL) {
"devAiStats (init_record) Illegal INP parm field");
/* Make sure record processing routine does not perform any conversion*/
pr->linr=0;
pr->dpvt=pvt;
pr->hopr = 100.0;
pr->lopr = 0.0;
pr->prec = 2;
return 0;
int type;
devPvt* pvt = NULL;
char *parm;
if(pr->out.type!=INST_IO) {
"devAoStats (init_record) Illegal OUT field");
parm = pr->out.value.instio.string;
if(strcmp(parm,aoparmValue[type])==0) {
pvt->type=type;
pr->val = default_scan_rate[type];
if(pvt==NULL) {
"devAoStats (init_record) Illegal OUT parm field");
pr->linr=0;
pr->dpvt=pvt;
return 2;
static long ao_write(aoRecord* pr)
if(!pvt) return(0);
if(pr->val<=1.0) pr->val=1.0;
scan[pvt->type].rate_tick = (int)pr->val * sysClkRateGet();
return 0;
static long ai_read(aiRecord* pr)
double value = 0.0;
if(!pvt) return(0);
switch(pvt->type) {
case MEMORY_TYPE: value = getMemory(); break;
case CPU_TYPE: value = getCpu(); break;
case FD_TYPE: value = getFd(); break;
default: recGblRecordError(S_db_badField,(void*)pr,"Illegal type");
pr->val=value;
pr->udf=0;
return 2; /* don't convert */
scanIoRequest(scan[type].ioscanpvt);
wdStart(scan[type].wd,scan[type].rate_tick, (FUNCPTR)wdCallback,type);
/*Memory statistics*/
#include <memLib.h>
static MEM_PART_STATS meminfo;
double nfree,nalloc;
memPartInfoGet(memSysPartId,&(meminfo));
nfree = meminfo.numBytesFree;
nalloc = meminfo.numBytesAlloc;
return(100.0 * nalloc/(nalloc + nfree));
/* fd usage */
#include <private/iosLibP.h>
static double getFd()
int i,tot;
for(tot=0,i=0;i<maxFiles;i++) {
if(fdTable[i].inuse)
tot++;
return(100.0*(double)tot/(double)maxFiles);
unsigned long ticksLastUpdate = usage.ticksLastUpdate;
unsigned long ticksNow = tickGet();
if(ticksNow>=ticksLastUpdate /*ignore tick overflow*/
&& (ticksNow-ticksLastUpdate) >= usage.ticksToDeclareStarvation) {
usage.usage = 100.0;
scanIoRequest(scan[CPU_TYPE].ioscanpvt);
wdStart(scan[CPU_TYPE].wd,scan[CPU_TYPE].rate_tick,(FUNCPTR)wdCpu,0);
int i;
double result = 0.0;
for(i=0;i<5; i++) result += sqrt((double)i);
return(result);
while(TRUE) {
unsigned long tickStart,tickEnd=0;
int nBurnNow;
double nBurnNoContention = (double)usage.nBurnNoContention;
double nBurnContention,newusage;
nBurnNow=0;
tickStart = tickGet();
while(1) {
cpuBurn();
++nBurnNow;
tickEnd = tickGet();
if(tickEnd<tickStart) break; /*allow for tick overflow*/
if((tickEnd - tickStart) >= usage.ticksToBurn) break;
if(tickEnd<tickStart) continue; /*allow for tick overflow*/
nBurnContention = (double)nBurnNow;
newusage = 100.0*((nBurnNoContention - nBurnNow)/nBurnNoContention);
semTake(usage.lock,WAIT_FOREVER);
usage.usage = newusage;
semGive(usage.lock);
taskDelay(usage.ticksToWait);
usage.ticksLastUpdate = tickEnd;
static double getCpu()
double value;
value = usage.usage;
return(value);
unsigned long tickStart,tickEnd=0,tickNow;
int nBurnNoContention=0;
usage.lock =
semMCreate(SEM_DELETE_SAFE|SEM_INVERSION_SAFE|SEM_Q_PRIORITY);
usage.usage = 0.0;
usage.ticksToDeclareStarvation = SECONDS_TO_STARVATION * sysClkRateGet();
usage.ticksToWait = SECONDS_TO_WAIT*sysClkRateGet();
usage.ticksToBurn = SECONDS_TO_BURN*sysClkRateGet();
/*wait for a tick*/
while(tickStart==(tickNow = tickGet())) {;}
tickStart = tickNow;
while(TRUE) {
cpuBurn();
nBurnNoContention++;
if(tickEnd<tickStart) break; /*same test as cpuUsageTask*/
if(tickEnd<tickStart) printf("cpuUsageInit logic error\n");
usage.nBurnNoContention = (double)nBurnNoContention;
usage.ticksLastUpdate = tickGet();
taskSpawn("cpuUsageTask",255,VX_FP_TASK,3000,(FUNCPTR)cpuUsageTask,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0);
- devVXStats and task crash Andy Foster
- Re: devVXStats and task crash Marty Kraimer
Re: dbCaLink and broadcast messages Kevin Tsubota
RE: dbCaLink and broadcast messages Jeff Hill
<2001>
2025
2026
New MCP750s That Don't Run VxWorks Boot Code Susanna Jacobson
<2001>
2025
2026
