Benjamin Franksen wrote:
> Andrew Johnson wrote:
> > when Marty pointed out that by introducing a new state into
> > menuConvert.dbd we would break any existing applications that add their
> > own breakpoint tables (because they provide their own copy of
> > menuConvert.dbd and are only allowed to add items to the end of the menu
> > defined in base), and possibly the AllenBradley 1771IXE device support
> > which apparently makes assumptions about the LINR field. Aarrrgghh!!!
> > These changes can be made, but probably not in a minor release (breaking
> > backwards compatibility is generally verboten for minor releases). Thus
> > Marty is willing to accept the above in 3.14, but not in a 3.13.x release.
I will fix the 1771IE support so that it will work with the new state added to
menuConvert.
It is still not nice because there is no way to guarantee that allenBradley is
built with the same menuConvert.h as an application that uses the allen bradley
support.
Please note that this is in the allenBradleyApp/oldSrc/devAB1771IXE.c code.
There newer support in allenBradleyApp/1771IXSrc that does not have these
problems. The new support also supports more features of the 1771IXE.
As I recall this kludge was done when extensible record/device support was first
implemented.
There are comments in the code stating that there must be a better way. There
is. Use the newer support. The problem is that existing application use the old
support. Some were implemented so long ago that even the person who did it will
not remember doing it. Thus we must try to keep compatible.
Marty Kraimer
- RE: RAWF, RAWL Redman, Russell O.
- Re: RAWF, RAWL Marty Kraimer
- Re: RAWF, RAWL Benjamin Franksen
- Re: RAWF, RAWL Andrew Johnson
Re: An additional remark on C++ Benjamin Franksen
<2001>
2025
2026
<2001>
2025
2026
ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
