> It appears that the cut-off in the addressing is not in the mail
> forwarding but in the alarm handler reading its configuration file.
> What is the limit on the line length in alarm handler config files?
Oops,
the config file line length is limited by a buffer which is of length
MAX_STRING_LENGTH, i.e. 500 (defined in alh.h).
It never appeared to me that this might be too short, but it obviously
is.
If I understand correctly, the ... exceptional length of your config
file lines is due to listing multiple mail addresses. Even without
having detailed knowledge about your mail forwarding scheme ... I would
always try to have alh call a (shell or perl) script instead of
populating the alh config file with email addresses. This not only keeps
config file lines short, it also nicely separates things: you don't have
to restart the alh (with all the additional log entries and stuff) just
because you changed the mail address lists. Also, a script could do
additional checking, e.g. don't send mails if a file called _SHUTDOWN_
exists - we use such a mechanism to keep things quiet in shutdown
periods with zillions of bogus alarms.
Cheers,
Ralph
- Re: alarm handler confusion (and solution) Maren Purves
- alarm handler confusion (and solution) Maren Purves
Image capture Rolf Keitel
<2001>
2025
2026
<2001>
2025
2026
