Ian A Smith wrote:
> Hi,
> I'm just about to start an epics project and wonder how advisable it
> would be to try and run 3.14 under Linux. The only hard records
> required would be an analogue with dev/drv support to talk to the serial
> port of the pc. All other records would be soft. I also need dm
> screens and remote CA.
> Is this feasable now or is it known when it would become so?
All of the IOC stuff listed above (and the sequencer too) should work
fine on linux with 3.14-beta1. I've even successfully run the GPIB/LAN
adapter driver from a Linux IOC application. I use medm, which seems to
work for the limited amount of stuff I've tried, but I've not tried dm.
How do you plan to communicate with the hardware? Linux allows
user-level in/out instructions which makes basic device access very
simple. You need only supply a setuid-root wrapper around your
application to gain access to the range of I/O ports you need.
Eric Norum [email protected]
Department of Electrical Engineering Phone: (306) 966-5394
University of Saskatchewan FAX: (306) 966-5407
Saskatoon, Canada.
- Re: 3.14 on Linux Andrew Johnson
- 3.14 on Linux Ian A Smith
Re: 3.14 on Linux Matthieu Bec
<2001>
2025
2026
<2001>
2025
2026
