1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 3.14 on Linux
Cc: [email protected]
Date: Mon, 24 Sep 2001 08:54:29 -1000
Hi Ian,
Sure it is feasible: I'm driving a very simple serial device through
Epics/Linux, haven't seen any problem so far. DM and
channel access also work without problem on that platform.
Other than that, I can't tell if it's recommandable because the release
is still alpha ! maybe it depends on how critical is your system, for us
it's a couple of monitoring devices, so I'm pushing forward for that
kind of solution.
being just next door, I could give you a quick demonstration if you
wished,
 Matthieu
Matthieu Bec              Gemini Observatory
Tel: +1 808 9742557       670 N. A'ohoku Place
Fax: +1 808 9359235       Hilo, Hawaii 96720, USA
Ian A Smith wrote:
> Hi,
> I'm just about to start an epics project and wonder how advisable it
> would be to try and run 3.14 under Linux.  The only hard records
> required would be an analogue with dev/drv support to talk to the serial
> port of the pc.  All other records would be soft.  I also need dm
> screens and remote CA.
> Is this feasable now or is it known when it would become so?
> Thanks.
> Ian A Smith     Telephone: (808) 961 3756
> Joint Astronomy Centre    Fax:       (808) 961 6516
> 660 N. A'ohoku Place        (808) 969 6591
> University Park     Web: http://www.jach.hawaii.edu
> Hilo
> Hawaii
> 96720
3.14 on Linux Ian A Smith
Prev: Re: 3.14 on Linux Eric Norum
Next: Re: 3.14 on Linux Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: 3.14 on Linux Andrew Johnson
Next: serial stuff on r3.14 Allan Honey
