Eric Norum wrote:
> Ian A Smith wrote:
> > I'm just about to start an epics project and wonder how advisable it
> > would be to try and run 3.14 under Linux. The only hard records
> > required would be an analogue with dev/drv support to talk to the serial
> > port of the pc. All other records would be soft. I also need dm
> > screens and remote CA.
> How do you plan to communicate with the hardware? Linux allows
> user-level in/out instructions which makes basic device access very
> simple. You need only supply a setuid-root wrapper around your
> application to gain access to the range of I/O ports you need.
As he's only using serial ports, he should be able to just open the
relevent /dev/ttySn port from user mode, thus even an suid wrapper may be
unnecessary.
I think this would be an ideal project for 3.14. You might want to wait
for the first Beta release which is supposed to be coming out Real Soon
Now[TM], but you could start looking at the Linux end of your serial
driver in the meantime.
- Andrew
Perfection is reached, not when there is no longer anything to add,
but when there is no longer anything to take away.
- Antoine de Saint-Exupery
- 3.14 on Linux Ian A Smith
- Re: 3.14 on Linux Eric Norum
Re: 3.14 on Linux Matthieu Bec
serial stuff on r3.14 Allan Honey
<2001>
2025
2026
<2001>
2025
2026
