1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: PowerPC woes
To: "'john sinclair '" <[email protected]>, Mark Rivers <[email protected]>
Cc: "'Nick Rees '" <[email protected]>, "'[email protected] '" <[email protected]>
Date: Fri, 16 Nov 2001 09:31:13 -0600
Title: RE: PowerPC woes
> Nick Rees wrote:
> > While I'm on it, I was using a PowerPC mvme2402 for some of these
tests. I
> > am running Tornado 2.0.2. Whenever the PPC reboots it spends ages
doing
> > apparently nothing (i.e. about 3 minutes) just before it prints out
the
> > Attaching TCP/IP and network interface messages (i.e. very eearly in
the
> > boot).
> > Does anyone have any idea how to get rid of this. It does it twice,
so
> > waiting 5-6 minutes every boot is a bit of a bore.
I have a different suggestion from Andrew's.  I have seen a very similar problem to the on Nick describes on the MVME2700.  The problem is actually with the Ethernet 10/100 autonegotiation.  If I plug the Ethernet into a 10/100 Hub it works fine.  If I plug it into certain types of Ethernet switches (e.g. Cisco 2924 I think) it takes several minutes, and it does it twice as Nick observed. Try using a different physical device and see if it improves.
RE: PowerPC woes Nick Rees
Prev: Re: PowerPC woes john sinclair
Next: Re: PowerPC woes Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: TPMC880-10 Ethernet card for PPC. Vladis Korobov
Next: RE: PowerPC woes Nick Rees
