1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: PowerPC woes
Cc: "'[email protected] '" <[email protected]>
Date: Fri, 16 Nov 2001 10:38:39 -1000 (HST)
On Fri, 16 Nov 2001, Mark Rivers wrote:
> I have a different suggestion from Andrew's.  I have seen a very similar
> problem to the on Nick describes on the MVME2700.  The problem is actually
> with the Ethernet 10/100 autonegotiation.  If I plug the Ethernet into a
> 10/100 Hub it works fine.  If I plug it into certain types of Ethernet
> switches (e.g. Cisco 2924 I think) it takes several minutes, and it does it
> twice as Nick observed. Try using a different physical device and see if it
> improves.
I have tried four configurations:
1. An autoconfiguring 10/100 switch (Allied Telesyn),
2. An autoconfiguring 10/100 hub (SMC)
3. A fixed 10 base T switch (Allied Telesyn)
4. A fixed 100 base TX hub (Allied Telesyn).
All with no result. Sob. Sob.
I have also tried changing the address translation stuff as per Andrew's
suggestions, but to no avail. However, I may have got it wrong, so I will
continue to think about it.
Cheers,
Nick Rees
Joint Astronomy Centre               Ph:       +1 (808) 961-3756
660 N. Aohoku Place                  Fax:      +1 (808) 961-6516
Hilo, HI.  96720                     Internet: [email protected]
RE: PowerPC woes Mark Rivers
Prev: Re: PowerPC woes Andrew Johnson
Next: RE: PowerPC woes Kevin Tsubota
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: PowerPC woes Mark Rivers
