1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PowerPC woes
To: john sinclair <[email protected]>
Cc: [email protected]
Date: Fri, 16 Nov 2001 09:50:57 -0600
john sinclair wrote:
> What is the sysBatDesc[] table and does it exist in the x86 architecture?
It's a PowerPC thing; I don't know if anything equivalent exists in that
architecture.  The 68K equivalent is the Transparent Translation registers
(TTRegs) if that helps.
> Mapping memory for PCI devices via sysPhysMemDesc is similarly
> problematic.
I suspect that some of the delay may be related to the autoconfiguration
of the PCI bus - our MVME2100 boards that do autoconfig take something
like 10+ seconds longer to startup than our MVME2700 boards which don't.
If you don't autoconfigure, it's obviously possible to create suitable
sysPhysMemDesc[] entries for the hardware which you have to know about in
advance.
However having had a private email exchange with Nick last night I now
think that Mark's suggestion of the network autonegotiation is likely to
be the main culprit in his case.
- Andrew
Perfection is reached, not when there is no longer anything to add,
but when there is no longer anything to take away.
- Antoine de Saint-Exupery
Re: PowerPC woes john sinclair
Prev: RE: PowerPC woes Mark Rivers
Next: RE: PowerPC woes Nick Rees
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PowerPC woes john sinclair
Next: devNode, drvNode, drvSerial source? Steven Hartman
