> Is this behavior reasonable? Does pend event do something fundamentally
> different from pend io?
Yes. If you have not made any of the following IO requests since the last
call to ca_pend_io() (or the start of the program whichever is first), then
ca_pend_io() will have no effect other than to flush the output queue,
and ca_pend_io() will return immediately without blocking for the duration
of the specified time out.
1) created a CA channel (without specifying a connection call back handler)
2) made a CA get request (without specifying an IO completion call back handler)
In contrast ca_pend_event() will always process CA background activity
for the full duration of the specified timeout and until all queued
labor has been processed by CA.
You should call ca_poll() or ca_pend_event(1e-12) in the background at least
a 10 Hz rate. Alternatively, in EPICS R3.14 if your application is thread safe,
you can enable preemptive call backs and not bother with polling ca_pend_event().
Jeff
> In the course of testing edm, I have noticed the following behavior for
> some configurations (unfortunately, I don't mean anything precise when I
> say "some configurations"):
> I run a fresh copy of edm, bring up a display containing ~9000
> references to the same pv and execute it. This adds ~9000 events to the
> ioc (or portable CAS). Performance is good.
> I now deactivate the display which clears all the events.
> From this point on, when this or any other display is executed, the
> performance is such that it takes twice as long to complete the
> process of adding all the events.
> At this point the code looked something like the following:
> for all pvs {
> add events
> ca_pend_io( time )
> So, I changed this to
> count=0
> for all pvs {
> add events
> if ( ++count > someNumber ) {
> ca_pend_io( time )
> count=0
> ca_pend_io( time )
> This did not help at all. Then I change to code to
> count=0
> for all pvs {
> add events
> ca_pend_io( time )
> ca_pend_event( small-time )
> count=0
> ca_pend_io( time )
> This made an amazing difference and now the performance is good all the
> time.
> John Sinclair
> [email protected]
> Oak Ridge National Lab
> 865-576-6362 865-574-1268 (fax)
- RE: channel access john sinclair
- channel access john sinclair
RE: Error message from sequencer Jeff Hill
RE: channel access Coleman, Thomas A.
<2001>
2025
2026
<2001>
2025
2026
