In the course of testing edm, I have noticed the following behavior for
some configurations (unfortunately, I don't mean anything precise when I
say "some configurations"):
I run a fresh copy of edm, bring up a display containing ~9000
references to the same pv and execute it. This adds ~9000 events to the
ioc (or portable CAS). Performance is good.
I now deactivate the display which clears all the events.
From this point on, when this or any other display is executed, the
performance is such that it takes twice as long to complete the
process of adding all the events.
At this point the code looked something like the following:
for all pvs {
add events
ca_pend_io( time )
So, I changed this to
count=0
for all pvs {
add events
if ( ++count > someNumber ) {
ca_pend_io( time )
count=0
ca_pend_io( time )
This did not help at all. Then I change to code to
count=0
for all pvs {
add events
ca_pend_io( time )
ca_pend_event( small-time )
count=0
ca_pend_io( time )
This made an amazing difference and now the performance is good all the
time.
Is this behavior reasonable? Does pend event do something fundamentally
different from pend io?
John Sinclair
[email protected]
Oak Ridge National Lab
865-576-6362 865-574-1268 (fax)
- RE: channel access Jeff Hill
Fwd: RE: PowerPC woes Dale L. Brewe
RE: bad UDP messages Jeff Hill
<2001>
2025
2026
Re: Fwd: RE: PowerPC woes David H. Thompson
<2001>
2025
2026
