1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Problem building 3.14 application with ipac/CANbus
To: EPICS Techtalk <[email protected]>
Cc: "'Janet Anderson'" <[email protected]>, "'Marty Kraimer'" <[email protected]>, "Wermelskirchen, Clemens" <[email protected]>
Date: Mon, 18 Feb 2002 12:12:28 -0800
	Folks,
I was unable to build Andrew Johnson's ipac/CANbus support into a 3.14 application.  Janet Anderson replied
> The bus/ipac module has not been converted to R3.14 yet.
> To get build backward compatability to the R3.13 ipac you could
> try the following -
> The R3.13  ipacLib and tip810lib files are only built for vxWorks
> targets, so you will need to first change  PROD_IOC = example
> to PROD_IOC_vxWorks = example.
> The R3.13 ipacLib and tip810Lib files are combined object files
> not archive libraries so to add them to your R3.14 application
> PROD try adding
>      example_LDFLAGS_vxWorks += $(IPAC_BIN)/ipacLib
>      example_LDFLAGS_vxWorks += $(IPAC_BIN)/tip810Lib
> Adding
>      example_OBS_vxWorks += $(IPAC_BIN)/ipacLib
>      example_OBS_vxWorks += $(IPAC_BIN)/tip810Lib
> will not work for R3.13 *Lib files unless you rename them by adding
> a  .o to the name (e.g. ipacLib to ipacLib.o).
> Hope this helps.
Did it ever!  Many thanks.  Now maybe I can do something fun with the rest of the weekend.
                                   --Harvey
Prev: Re: Problem building 3.14 application with ipac/CANbus Marty Kraimer
Next: Epics 3.14 build Korhonen Timo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
