I like it!
Perry could you please send me your drvNode code?
Not sure I have time to modify getFrame() and formatCmt().
Any takers?
AH
> Date: Fri, 19 Apr 2002 15:14:30 -0600
> From: "Peregrine M. McGehee" <[email protected]>
> In the simple drvNode framing routines I alluded to earlier
> we allowed a set of multiple terminators. On a character by
> character basis the index into each terminator was incremented until
> either a mismatch occurred or a complete terminator was found.
> While in our application we defined the terminators at the vxWorks command
> line, modifying the drvAscii <readCmt> construct would be
> straightforward.
> drvNode usage is:
> * A delimiter definition includes:
> * n - index into delimiter array [0..NDELIMITERS-1]
> * len - length of delimiter in characters. (0 = delimiter not defined)
> * delim - delimiter string
> * mask - bit mask indicating which positions are wild carded.
> * Examples:
> * drvNodeSetDelim(COMMON, 2, 2, "\015\012", 0x00)
> * delimiter #2 = CRLF
> * drvNodeSetDelim(MOUSE, 0, 3, " ", 0x07)
> * delimiter #0 = any sequence of three characters (useful
> * for mouse pointing devices).
> By adding two optional syntax elements to the drvAscii <readCmt>
> links this could be emulated, i.e.
> o add an optional delimiter number (default=0)
> o allow a %k construct within the terminator string
> (default = not used).
> So the examples above could be written as:
> field(OUT,"@COMMON <readCmt 2 %s>")
> field(VAL,"\015\012")
> and
> field(OUT,"@MOUSE <readCmt %s>")
> field(VAL,"%3k").
> Note that drvNode returns the terminator string.
> - Peregrine
> Peregrine M. McGehee [email protected] (505) 667-3273
> Sloan Digital Sky Survey / Spallation Neutron Source
> MS H820, Los Alamos National Laboratory, Los Alamos, NM 87545
- Re: drvAscii - termintor strategy Peregrine M. McGehee
<2002>
2025
2026
Re: drvAscii - termintor strategy Allan Honey
<2002>
2025
2026
