1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Access to device support debugging vars via iocsh (3.14b2)
To: "S. Joshua Stein" <[email protected]>
Cc: [email protected]
Date: Mon, 19 Aug 2002 15:55:17 -0500
re...,
"S. Joshua Stein" wrote:
> I would like to set a (global) debugging variable which is part of my device
> support running on a solaris IOC (3.14b2). In the vxWorks world, I would just
> type:
> >deviceDebugVar=1
> This, however, won't work with iocsh. Does anyone know if/how I can gain access
> to these variables?
How about connecting an AO record to the global symbol, using devAoSymb
device support?
Then you could set the variable from any CA client.
Tim Mooney
Re: Access to device support debugging vars via iocsh (3.14b2) Andrew Johnson
Re: Access to device support debugging vars via iocsh (3.14b2) Eric Norum
Access to device support debugging vars via iocsh (3.14b2) S. Joshua Stein
Prev: Re: Access to device support debugging vars via iocsh (3.14b2) Eric Norum
Next: Re: Access to device support debugging vars via iocsh (3.14b2) Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
