Tim Mooney wrote:
> "S. Joshua Stein" wrote:
> > I would like to set a (global) debugging variable which is part of my device
> > support running on a solaris IOC (3.14b2). In the vxWorks world, I would just
> > type:
> > >deviceDebugVar=1
> > This, however, won't work with iocsh. Does anyone know if/how I can gain access
> > to these variables?
> How about connecting an AO record to the global symbol, using devAoSymb
> device support?
> Then you could set the variable from any CA client.
That relies on someone having converted the vxWorks symbol support to use
the R3.14 symbol registration routines (which I don't believe has been
done yet, but I might be wrong there), and Josh would still have to
register the address of his debug variable with the registration
facility. It should be possible to do that within a device support
initialization routine rather than having to write the C++ static
initializer routine that Eric was describing, but Eric's solution is
probably simpler overall until vxSymb gets properly converted to R3.14.
- Andrew
Edsger W. Dijkstra, 1930-2002: "The use of COBOL cripples the mind;
its teaching should, therefore, be regarded as a criminal offence."
- Access to device support debugging vars via iocsh (3.14b2) S. Joshua Stein
- Re: Access to device support debugging vars via iocsh (3.14b2) Tim Mooney
Re: Access to device support debugging vars via iocsh (3.14b2) Eric Norum
<2002>
2025
2026
<2002>
2025
2026
