1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VDCT groups
To: Geoff Savage <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 03 Dec 2002 16:14:48 +0100
You can already edit/generate template files, but not yet in combination
with the generator files that are the input files to dbLoadTemplate.
VisualDCT allows for each "Menu" field either one of the valid choices,
or the input from a substitution variable. Like for example a SCAN
field can be set to one of the items from the menuScan in the dbd file
or from a variable like for example $(SCAN_RATE).
Since the value of that variable is not known to VDCT, it cannot
do syntax checking for it.
Those variables can be used in record names, too. Here VDCT can
at least show the link destination: if it is within the same database,
it should be referred by with the same variable in the name.
If VDCT would also handle the generator files, it could do full
syntax checking on the expanded db files. Then a wrong assignement
to a substitution variable in a generator file would show up as an error.
Andreas
Geoff Savage wrote:
> Luedeke Andreas wrote:
> > I.e. dbLoadTemplate should
> > be extended or replaced to load databases with this syntax.
> Is it possible to generate template and generator files from VDCT?  We
> use both of these file types to populate our Oracle database from which
> we generate .db files.  I also find it handy to do development work with
> a template and generator file.
> Geoff
Re: VDCT groups Andrew Johnson
VDCT groups John Maclean
Re: VDCT groups Matthias Clausen
Re: VDCT groups Luedeke Andreas
Re: VDCT groups Geoff Savage
Prev: Re: VDCT groups Geoff Savage
Next: Re: VDCT groups John Maclean
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: VDCT groups Andrew Johnson
