The spec for VDCT hierarchies does not use the old substitutions file format (which I presume is what you mean by a "generator file"), we're combining the two file types using a single syntax. This will need some some changes to existing systems that currently generate substitutions files, but the difference is small and the results are much easier to understand at a glance. This will be the syntax to expand a template: expand("slideMotor.vdb", slmot1) {
macro(name, "sm1")
macro(address, "4")
macro(demand, "slide1:demand.VAL")
}This expands the slideMotor.vdb template file with the given macro values. The "slmot1" argument to expand() is a name for this instance of the template, and is needed for the new hierarchy port functionality (which will allow a template to pass values back up to the calling .vdb file). For the time being VDCT will be the only tool capable of flattening .vdb hierarchies, but I'll be including a suitable command-line tool in R3.15 and by then the IOC itself may also be capable of doing the flattening at load time (although booting may be quicker if you load a pre-flattened .db file instead). Luedeke Andreas replied: > > If VDCT would also handle the generator files, it could do full > syntax checking on the expanded db files. Then a wrong assignement > to a substitution variable in a generator file would show up as an > error. I'm not sure that we're asking Matej to do syntax checking across diagrams like that, but I might be wrong. In any case it will still be possible to check the syntax of the .db file after the hierarchy has been flattened by feeding the .db file into dbReadTest. - Andrew -- "Life is what happens while you're busy making other plans." - John Lennon
| ANJ, 10 Aug 2010 |
Home
News
About
Talk
Base
Modules
Extensions
