1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: caRepeater R3.13 vs. R3.14
To: "'[email protected]'" <[email protected]>
Date: Thu, 03 Apr 2003 11:30:41 -0600
When I first tried to run ca_test after building R3.14.1 on Linux I received a segmentation fault. After killing caRepeater and running ca_test again everything worked fine. As I suspected the interaction with a R3.14 CA client with a R3.13 caRepeater is not optimal. Is this the expected behaviour? Ca_test from R3.13 does work with the R3.14 caRepeater.
Geoff
RE: caRepeater R3.13 vs. R3.14 Jeff Hill
Prev: Re: stringIn record monitors Brian McAllister
Next: problems switching ioc's ip address Dale L. Brewe
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: stringIn record monitors Andrew Johnson
Next: RE: caRepeater R3.13 vs. R3.14 Jeff Hill
