Marty Kraimer wrote:
> Benjamin Franksen wrote:
> > Hi Marty (and all),
> > one important limitation (at least in 3.13.x) is missing in appDevGuide:
> > dbNotifyCancel must not be called from interrupt context.
> > I did and very bad things happened. BTW, i wonder what will happen if
> > such a record (i.e. one with asynch soft support) is processed as a
> > result of a ca_put_calback. Hmmm...
> VERY few things can be called from interrupt context.
> The Application Developer's Guide says if a routine can get called from
> interrupt routines. If it does not say this it should be assumed that the
> routine can't be called from interrupt context.
Correct. It was stupid of me to assume that calling dbNotifyCancel from
the interrupt routine was safe. I simply didn't think about it.
> Note that the following can be called from interrupt level
> callbackRequest
> callbackRequestProcessCallback
> scanIorequest
> One of these should be all you need. For example callbackRequest can cause a
> user supplied routine to be called by a general purpose callback thread.
That's exactly what i did, then, and it immediately worked fine.
Cheers,
Ben
PS: I finally understood the S_db_Blocked issue (after reading the code
in base and then re-reading the doc): S_db_Blocked is only returned if
an existing put notify block in the target record is the *same* object
(address comparison) as the one that is now being given as argument.
Multiple putNotifies to the same target record seem to be no problem at
all as long as they come from different clients, otherwise they are
ignored. This is make sense, indeed. The Developer's Guide could be a
little more clear on this point; it says "If a putNotify is already
active..." which is of course fine if one already knows what is meant.
- Re: recDynLink.c for R3.14.1 ? Marty Kraimer
- Re: recDynLink.c for R3.14.1 ? Tim Mooney
- RE: recDynLink.c for R3.14.1 ? Feng, Shuchen
- Re: recDynLink.c for R3.14.1 ? Kate Feng
- Re: recDynLink.c for R3.14.1 ? Benjamin Franksen
Contact for EPICS Collaboration Meeting in June Michael Oothoudt
macTest Kevin Tsubota
<2003>
2025
2026
<2003>
2025
2026
