1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: recDynLink.c for R3.14.1 ?
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Thu, 17 Apr 2003 06:36:46 -0500
Benjamin Franksen wrote:
PS: I finally understood the S_db_Blocked issue (after reading the code
in base and then re-reading the doc): S_db_Blocked is only returned if
an existing put notify block in the target record is the *same* object
(address comparison) as the one that is now being given as argument.
Multiple putNotifies to the same target record seem to be no problem at
all as long as they come from different clients, otherwise they are
ignored. This is make sense, indeed. The Developer's Guide could be a
little more clear on this point; it says "If a putNotify is already
active..." which is of course fine if one already knows what is meant.
What version of base are you using?
In the 3.14.1 version, S_db_Blocked is defined in a header file but never used.
In section 15.4.4 of the 3.14.1 Application Developer's Guide explains the Put Notify Routines. As far as I know this section gives a correct explaination of how they work except that the reference to putNotifyBlocked should be removed.
Am I missing something?
RE: recDynLink.c for R3.14.1 ? Feng, Shuchen
Re: recDynLink.c for R3.14.1 ? Tim Mooney
Re: recDynLink.c for R3.14.1 ? Kate Feng
Re: recDynLink.c for R3.14.1 ? Benjamin Franksen
Re: recDynLink.c for R3.14.1 ? Marty Kraimer
Prev: Re: db_parse returned -1 M.C.Shao
Next: CAMAC problems Hammonds, John P.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: recDynLink.c for R3.14.1 ? Benjamin Franksen
Next: Re: recDynLink.c for R3.14.1 ? Tim Mooney
