1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: recDynLink.c for R3.14.1 ?
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Thu, 17 Apr 2003 23:05:16 -0500
Benjamin Franksen wrote:
> PS: I finally understood the S_db_Blocked issue (after reading the code
> in base and then re-reading the doc): S_db_Blocked is only returned if
> an existing put notify block in the target record is the *same* object
> (address comparison) as the one that is now being given as argument.
> Multiple putNotifies to the same target record seem to be no problem at
> all as long as they come from different clients, otherwise they are
> ignored. This is make sense, indeed. The Developer's Guide could be a
> little more clear on this point; it says "If a putNotify is already
> active..." which is of course fine if one already knows what is meant.
Uh-oh.  This isn't the way I understood putNotify.  It would be a disaster
for one client to initiate a putNotify trace on the same record, or even a
different record in the same lockset, as an ongoing putNotify trace.  How
could you ensure that the two execution traces would not interfere with
each other?
Tim Mooney ([email protected]; 630-252-5417)
Advanced Photon Source
APS Operations Division
Beamline Controls & Data Acquisition Group
RE: recDynLink.c for R3.14.1 ? Feng, Shuchen
Re: recDynLink.c for R3.14.1 ? Tim Mooney
Re: recDynLink.c for R3.14.1 ? Kate Feng
Re: recDynLink.c for R3.14.1 ? Benjamin Franksen
Re: recDynLink.c for R3.14.1 ? Marty Kraimer
Prev: CAMAC problems Hammonds, John P.
Next: Re: recDynLink.c for R3.14.1 ? Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: recDynLink.c for R3.14.1 ? Marty Kraimer
