1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Timezone
To: TECHTALK <[email protected]>
Date: Wed, 21 May 2003 15:38:55 +0200
Hello Andy,
does that mean I have to fix EPICS_TIMEZONE every year?
Our CA clients have been built with R3.13.2 and EPICS_TIMEZONE is not mentioned in base/config/. Will that environment variable work with our clients?
Browsing the 3.13.2 code, I could only find TIMEZONE in drvTS.c and that is vxWorks code. How is the client software affected by this? Aren't EPICS time stamps time zone independent?
Dirk
Andy Foster wrote:
Hi Dirk,
I'm not sure which EPICS release you're using but I noticed this
in 3.14.1:
base/configure/CONFIG_SITE_ENV
# Time service:
# EPICS_TIMEZONE needed for vxWorks
# EPICS_TIMEZONE=<name>::<minutesWest>:<start daylight>:<end daylight>
#  DST for 2003  US: Apr  6 - Oct 26
#                EU: Mar 30 - Oct 26
EPICS_TIMEZONE=GMT::0:033003:102603
Cheers,
Andy
On Wed, 21 May 2003, Dirk Zimoch wrote:
when daylight saving time started this spring, I noticed that time
stamps hadn't been displayed correctly. I wodered if CA didn't support
daylight saving and changed EPICS_TS_MIN_WEST from -60 to -120. But now,
the time is out of sync again. Obviously EPICS does support daylight
saving time but uses other start (and end?) dates than we do in Europe.
What do I have to configure to make EPICS use the correct daylight
saving time?
Dirk
Dr. Dirk Zimoch
Swiss Light Source
Paul Scherrer Institut
Computing and Controls
phone +41 56 310 5182
fax   +41 56 310 4413
Observatory Sciences Limited    Email: [email protected]
William James House             Tel: 44 - (0)1223 - 508259
Cowley Road                     Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK          http://www.observatorysciences.co.uk
Dr. Dirk Zimoch
Swiss Light Source
fax   +41 56 310 4413
Re: Timezone Marty Kraimer
Re: Timezone Andy Foster
Prev: EPICS collaboration meeting registration Hayton, TG (Tim)
Next: AW: [Fwd: Re: Explicit initializing of Sub-Record] Kuehne Joerg
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Timezone Andy Foster
Next: Re: Timezone Marty Kraimer
