1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Timezone
To: Dirk Zimoch <[email protected]>
Cc: TECHTALK <[email protected]>
Date: Wed, 21 May 2003 09:22:51 -0500
Dirk Zimoch wrote:
Hello Andy,
does that mean I have to fix EPICS_TIMEZONE every year?
Yes. This is a problem because of vxWorks.
Our CA clients have been built with R3.13.2 and EPICS_TIMEZONE is not mentioned in base/config/. Will that environment variable work with our clients?
Browsing the 3.13.2 code, I could only find TIMEZONE in drvTS.c and that is vxWorks code. How is the client software affected by this? Aren't EPICS time stamps time zone independent?
Yes. Epics time stamps use UTC. Thus they are OK.
Thus CA clients are NOT affected since they use epics time stamps.
The only problem is if code on an IOC converts an epics time stamp to an ascii string. For example the IOC shell date command does this. Thus if TIMEZONE is wrong date will report a different time than CA clients.
Marty Kraimer
Re: Timezone Andrew Johnson
Re: Timezone Andy Foster
Re: Timezone Dirk Zimoch
Prev: AW: [Fwd: Re: Explicit initializing of Sub-Record] Kuehne Joerg
Next: Re: Timezone Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Timezone Dirk Zimoch
