1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Timezone
To: Marty Kraimer <[email protected]>
Cc: Dirk Zimoch <[email protected]>, TECHTALK <[email protected]>
Date: Wed, 21 May 2003 09:53:19 -0500
Marty Kraimer wrote:
Dirk Zimoch wrote:
does that mean I have to fix EPICS_TIMEZONE every year?
Yes. This is a problem because of vxWorks.
This also depends on the version of base you're using - prior to R3.14 EPICS base used EPICS_TS_MIN_WEST and the US date rules for daylight savings time changes. In R3.14.x we decided it makes more sense to use the facilities the OS provides for timestamp conversions to local time, so the inconvenience of having to set EPICS_TIMEZONE each year is due to the vxWorks API (which isn't really their fault, DST rules are not uniform throughout the world and vxWorks is used pretty much everywhere). Note that EPICS_TS_MIN_WEST *might* still get used by some CA clients if they use the tsLib functions rather than the newer epicsTime facility to perform time conversions.
Our CA clients have been built with R3.13.2 and EPICS_TIMEZONE is not mentioned in base/config/. Will that environment variable work with our clients?
That version of base uses the old tsLib routines and EPICS_TS_MIN_WEST.
- Andrew
There are 10 types of people in the world:
Those who understand binary, and those who don't.
Re: Timezone Andy Foster
Re: Timezone Dirk Zimoch
Re: Timezone Marty Kraimer
Prev: Re: Timezone Marty Kraimer
Next: [no subject] l7a
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <20032004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS collaboration meeting registration Hayton, TG (Tim)
